August 26, 2023 at 8:20 pm
veerpal kaur
SubscriberHi,
I am facing issue in Interconnect. Interfacing K-Layout design(thermoptic phase shifter or ring resonator) into intercoonect ,it show library is not installed . kindly help me. Thank you
Message displayed in output window is like is:
Loading netlist 'C:/Users/kaurv/AppData/Local/Temp/tmp6pp6civx/VK_veerpal_kaur_main.spi'...
Parsing netlist...
Validating libraries and models... 3 errors(s) found:
(1) Error loading netlist: the element '::design kits::ebeam::ebeam_gc_te1550' is not available in the library.
(2) Error loading netlist: the element '::design kits::ebeam::ebeam_wg_integral_1550' is not available in the library.
(3) Error loading netlist: the element '::design kits::ebeam::ebeam_dc_halfring_straight' is not available in the library.
Error loading netlist: failed to create circuit.
Total elapsed time: 01:38:43
August 26, 2023 at 10:55 pm
Devika Padmakumar Nair
Ansys EmployeeHello,
Thanks for reaching out. The error you mention indicates that the compact model is missing from the elements library. The compact model library can be installed according to this
Install Compact Model Library – Ansys Optics
Let me know this solved the issue.
Regards
Devika
August 26, 2023 at 11:50 pm
veerpal kaur
SubscriberThank you Devika. Software is working now....
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7566
4424
2949
1414
1322
