September 10, 2023 at 5:03 pm
veerpal kaur
SubscriberHi. I am simulating this file (GSiP_1_RingMod_gds.txt.
from following link https://github.com/SiEPIC/SiEPIC-Tools/tree/master/Examples/GSiP/RingModTransceiver/Layouts. I am facing following issues:
1.
2. I run similar design in AMF technologyand connect to interconnect then it show this type of error signal.
4. Problem occur in all technology( AMF, GSIP, EBeam). Interfacing Klayout into interconnect is not working properly .
Thank you.
September 11, 2023 at 11:27 pm
Amrita Pati
Ansys EmployeeHi Veerpal,
Please follow the instructions on the following page: KLayout Interop Installation Instructions to make sure that you have followed all the steps to install the KLayout packages properly. Please let me know if you still face the issue. Thank you!Regards,
Amrita
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7690
4476
2957
1435
1322
