March 24, 2021 at 1:14 am
forsyth307
SubscriberHas anyone gotten this to work for a switched reluctance motor since its release?nI'm using 2021 R1 and every time I try to run the machine toolkit for an SRM it uses an auto generated external circuit to define the motor current. The problem is that it sets the current to zero for iteration, regardless of what I put as the current parameter, and thus creates an efficiency map using zero current. The external circuit is inaccessible.n -
March 24, 2021 at 3:33 pm
Deyu Li
Ansys EmployeeSRM is not working in 2021R1 in machine toolkit, and it will be available in 2021R2.n -
March 24, 2021 at 3:55 pm
forsyth307
SubscriberSRM is not working in 2021R1 in machine toolkit, and it will be available in 2021R2.https://forum.ansys.com/discussion/comment/112409#Comment_112409
Why would Ansys make available a feature that doesn't actually work yet?n -
April 1, 2021 at 3:57 pm
Hyacinth
I got the same problem there. 2021R1 is not working for SRM efficiency calculation.nSo when would R2021R2 be available for users?nThanks!n
- Maxwell, HFSS or Q3D?
- Error
2522
2064
1279
1094
456
