September 10, 2019 at 5:59 pm
alitabei
SubscriberHi, I am seeing these two errors (RSM report screen shot and WB screenshot) when trying to run ANSYS on cluster with RSM.
I checked our license status with lmstat command see no license is being used, all the licenses are available.
Any help is appreciated.
September 10, 2019 at 11:28 pm
tsiriaks
Ansys EmployeeHey Ali,
When you checked lmstat, do you have license called 'ansys' or you have other licenses ? Can you provide the full list of licenses you have ?
Thanks,
Win
September 10, 2019 at 11:39 pm
alitabei
SubscriberHi Win,
Thanks for your response. Copied and pasted all the available licenses from lmstat. Please see here
September 11, 2019 at 12:14 am
tsiriaks
Ansys EmployeeAli,
Sorry, we are not allowed to access 3rd party links. Can you post the content of it inline ? You can take out the parts that show server hostname if you like.
Thanks,
Win
September 11, 2019 at 12:33 am
alitabei
Subscriberplease see below:
September 11, 2019 at 4:33 pm
tsiriaks
Ansys EmployeeThanks for the info Ali.
So, you really don't have the 'ansys' license but the solver specifically looked for it without checking for other licenses. There are 2 circumstances that will force server to do this.
1. User license preference: Check this folder ( ~/.ansys/v192/licensing/ ) in your home directory on the cluster and see if there is any file in there. If so, remove it
2. License specified in Solve Process settings: Check your local machine -> Mechanical GUI -> Solve Process Settings , to see what license is defined there. In your case, you should be using ANSYS Academic Research license.
Thanks,
Win
September 11, 2019 at 6:44 pm
alitabei
SubscriberThanks very much Win. The second thing (changing the license in my local machine) solved the issue! Our license got renewed on end of August and this must be a new thing , since I did not change anything on my solve process settings. Anyways, it is now working. Thanks again.
September 11, 2019 at 10:31 pm
tsiriaks
Ansys EmployeeGood to hear ! Thanks for the update Ali. I'm glad it's working now.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2706
2146
1357
1144
462
