May 1, 2022 at 6:06 pm
daniel1
SubscriberI am trying to simulate airflow in the model shown below.
May 2, 2022 at 1:00 pmSwathi V. V.
Ansys EmployeeHi Ensure that you have run the transient simulation sufficient for the fluid to flow through the entire domain.
Please go through the following video for setting up streamlines :ANSYS Fluent: Basic Post-processing - YouTubeandAerodynamics of a FSAE Car - Post processing in Fluent - Part 5 - YouTube.
Viewing 1 reply thread- The topic ‘Issue with simulating airflow’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
