Ansys Free Student Software
Issue with starting ANSYS Discovery 2022R1 Student
    • conls91
      I have downloaded ANSYS 20221R1, and I receive the following error message:
      "The application failed to initialize. This may be caused by an issue with the installation."
      I have tried uninstalling, removing all folders/files in the Program Files/ANSYS Inc directory, and reinstalling. No luck. I also see no install error logs in the program files directory. Any indications on how I can determine the issue, and resolve?
    • George Karnos
      After trying to start the program, can you check the Windows Event Viewer
      (in the search field on the task bar type in: Event Viewer)
      Once it appears, click on Windows Logs and then check the Application, setup, and System logs
      If you find any errors related to the program, please double-click on it and post a screenshot as we are not permitted to open files.
    • conls91
      Thanks for your reply. There were two errors in the 'Application' tab. Screenshots of the errors are attached.
    • George Karnos
      Please post screen shots as we are not permitted to open files.
    • conls91
      The screenshots aren't coming through for some reason. Here are copies of the error details:
      Error1:
      Application: Discovery.exe
      Framework Version: v4.0.30319
      Description: The process was terminated due to an unhandled exception.
      Exception Info: System.NullReferenceException
      at Apollo.Engine.Graphics.Tools.SurfaceAnimationToolWrapper+PInvoke.DestroyInstance(Apollo.Engine.Graphics.ApolloGraphics, Apollo.Engine.Graphics.Tools.SurfaceAnimationToolWrapper)
      at Apollo.Engine.Graphics.Tools.SurfaceAnimationToolWrapper.Dispose(Boolean)
      at Apollo.Engine.Graphics.Tools.SurfaceAnimationToolWrapper.Finalize Log Name: Application
      Source: .NET Runtime
      Event ID: 1026
      Level: Error
      Error 2:
      Faulting application name: Discovery.exe, version: 22.1.0.0, time stamp: 0x61a3bbd4
      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
      Exception code: 0xc0000005
      Fault offset: 0x00007ffad156f390
      Faulting process ID: 0x850
      Faulting application start time: 0x01d81389bc9ec93b
      Faulting application path: C:\Program Files\ANSYS Inc\ANSYS Student\v221\Discovery\Discovery.exe
      Faulting module path: unknown
      Report ID: 3a2c89dc-d399-454a-8c43-8c7709e33086
      Faulting package full name:
      Faulting package-relative application ID:
      Source: Application Error
      Event ID: 1000
      Level: Error
      Let me know if more info is needed. Thanks.
    • George Karnos
      Check the Graphics Card driver. Verify that it is the latest.
      The following is a search of the forum for the exception code 0xc0000005 https://forum.ansys.com/search?Search=0xc0000005 There are some other posts to look at...
    • conls91
      I've verified the graphics card version is the latest, and I am running the GPU that is recommended in the ANSYS downloads section.
      I've removed all ANSYS software and followed the advice of one post (for exception code 0xc0000005) to remove the app data for ansys from my computer. The other posts did not appear to be entirely relevant.
      Still no luck.
      I downloaded an earlier version of the Discovery Student (2021 R2) and it seems to be working fine.
      I have a SpaceClaim model for 2022R1, and since model export to .stp is no longer supported I'd still like to see if it is possible to get this running.... if any other advice is recommended, please let me know - thanks.
    • noormd
      While I am starting ansys 2022R1 (student version ) it will show an error like Level 2 all licence are reserved. then after some time application closes automatically.
    • noormd
      While I am starting Ansys Discovery 2022R1 (student version ) it will show an error like Level 1 is not available , a maximum number of demo users already reached. then after some time application closes automatically
    • DMoses
      Recently had a customer run into this error. The fix for them was as follows: Please try installing the VC_redist.x64.exe and vc_redist.x86.exe for Visual Studio 2015, 2017, 2019 and 2022 package. If they already have 2015 installed, you may need to uninstall before installing this downloaded version. https://docs.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170
Viewing 9 reply threads
