March 19, 2022 at 10:53 am
Mariah Ha
SubscriberHi,
I downloaded the transient example file from lumerical learning course, and ran it as it is. It is diverging. Please can anyone check this simulation?
March 22, 2022 at 9:53 pmGuilin Sun
Ansys EmployeeSorry to reply you late. Indeed this current file has the diverging issue. It is fixed now and will be released in ALH soon. Due to some changes, the course questions will also have some changes.
- Error on Lumerical device
2706
2146
1357
1144
462
