March 10, 2022 at 4:16 am
skdubey
SubscriberDear Friend,
I am trying to learn about the "UDF" in my application. I used the simple pipe case, at the initial inlet Pressure will increase with the flow-time and later on become a steady state. Outlet pressure is at 0 pa (gauge pressure). I am trying to plot the Inlet face pressure vs flow time, which should be a simple ramp-step function. I am not sure, I am not getting the desired ramp-step when I plot. I am not sure why my for loop is not read, is there anything wrong with the codes any suggestions
March 10, 2022 at 2:27 pmDrAmine
Ansys EmployeeDo you require an UDF for that? Actually a simple Fluent Expression will fit in. Even a transient table or profile will fit in.
Other point: Where are you hooking the UDF? Screenshot of panel, please.
March 10, 2022 at 2:30 pmRob
Ansys EmployeeI tend to use IF statements and keep things simple. So,
IF time< 10 pressure = whatever
ELSE pressure=something else
March 10, 2022 at 2:55 pmDrAmine
Ansys Employeethe slope is better handle via something like
myvalue= Current_Time*max_value/max_time that value to be hooked as Total Pressure in the Inlet Panel (assuming subsonic inlet where only that input is required).
And again better to use Expressions...
March 10, 2022 at 5:12 pmMarch 11, 2022 at 7:18 amDrAmine
Ansys Employee:)
Viewing 5 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
