Issue with UDF compilation
    • Dubey92
      I am compiling a UDF for my simulation but it is showing errors which are not there in the code. I am already using UDFs for my other simulations and they are working fine. I built a new model and tried to compile my UDF and it is giving syntax errors in the code. But I have checked thoroughly, those errors are not there. I have attached the image of the errors. Please someone help. Thank you
      The first line suggests a missing semi-colon.  Check the line above that too - once one of those goes missing you can get a load of false errors as the compiler flags things it thinks are on a single line of code.
      • Dubey92
        I really don't understand. I haven't faced this type of situation before. I don't think any punctuation is missing in the lines flagged.
      • Dubey92
        Nevermind. Got it. Two variables had same symbol. Thanks.
