November 8, 2019 at 9:25 pm
jtblue
SubscriberI am having issues generating a mesh for a blended wing body aircraft geometry. I've been following this tutorial: https://confluence.cornell.edu/display/SIMULATION/FLUENT+-+3D+Transonic+Flow+Over+a+Wing
The mesher takes about 30 minutes and then fails with the errors shown in the image below. I have tried numerous mesh sizes and types so I'm really not sure what to try next. I have also attached my simulation files.
November 12, 2019 at 2:21 pm
Ansys EmployeeCheck the geometry, then check the mesh settings you're using.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5454
3419
2473
1310
1022
