Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Issues on server for ANSYS operations
    • Shekhar1995
      I am using ANSYS on the server and accessing it through tiger VNC using mobaxterm. I am really trying hard to upload a CAD model on fluent meshing. The screen shows it is busy uploading and it shows the same for hours (even two days and when tried closing, it shows interrupting but never closes). Also, when I open fluent meshing, below warning appears
      "Software rasterizer found, hardware acceleration will be disabled.
      In the absence of hardware-accelerated drivers, the performance of all graphics operations will be severely affected. Make sure you have a supported graphics card, latest graphics driver, and a supported remote visualization tool with direct server-side rendering enabled. If you feel your system meets these requirements, try forcing the accelerated driver by using the command line flag (-driver ) or setting the HOOPS_PICTURE environment variable. Refer to the documentation for more details"
      Even when working with a fluent module on ANSYS workbench, while opening the geometry or mesh editor, it says "Unable to open geometry editor" or "Unable to open mesh editor" and it fails to mesh.
      Recently, I received a new laptop, with graphics card and ram configuration adequate to open ANSYS 2020 R2. So, I don't think the issue is with my laptop.
    • Keyur Kanade
      If you are running it on server, please check the hardware on server and not on your laptop. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • madanbk011
      I use the following command and it works while launching fluentn1) if you are using a workstation use: fluent -driver x11n2) if you're using an HPC cluster and use no dedicated visual graphics other than k80 and v100: fluent -driver opengl ( don't need a separate GPU for visualization in fluent ). if you face more problems after that. let me know at (madan.bk@wmich.edu)nhappy to help you...
