February 11, 2022 at 10:37 pm
ibak91
SubscriberHey all! I am relatively new to ANSYS Fluent, and I have been struggling with generating a volume mesh using polyhexcore aswell as tetra just to see if the issue was with polyhexcore as you can see from the second image it seems to cut the entire domain in half and leave chunks? I am using the Watertight geometry workflow and following a tutorial that is relatively close to what I am trying to achieve:
I am not too sure what the issue is, and I do not know what to Google to fix it, are there any tips or ideas to resolve this?
February 14, 2022 at 7:07 pmRK
Ansys EmployeeHello The second image is nothing but the auxiliary clipping plane which is checked. This will help you see the C/S of the geometry and the chunks are nothing but Poly cells. Just turn off the auxiliary clipping plane.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3930
2649
1861
1272
610
