August 15, 2018 at 9:17 pm
wallygator88
SubscriberI'm currently using Solidworks 2017, Workbench 17.2 and Maxwell 2016 on a research license.
I have a parallel plate style capacitor that was done in SW 2017. I've used a global variable to adjust the dimensions of my top and bottom plates simultaneously.
After importing the geometry into DM and generating the model, I can see the global variables and I am able to export them to Workbench as input paramters to use them in a parameteric analysis to determine the change in capacitance with the electrode dimensions. I'm also able to connect this to Maxwell, set up my simulation conditons and export output parameters (capacitance matrix) to the WB.
The issue that I'm seeing with my parametric analysis is that only DP1 updates and all remaining design points seem to show the same solution. I've noticed that the geometry in Maxwell does not refresh/update after the first design point and the following error shows up in Maxwell
[error] Link parameter 'P3@DS_SQ' in source system 'Geom' is mapped to constant '1' in target system. Map the link parameter to a design variable or project variable in the target system to enable synchronization. (4:09:29 PM Aug 15, 2018)
I'm not really sure how to go about debugging this or solving it and would appreciate any advice.
Thanks in advance!
August 17, 2018 at 3:44 am
Aniket
Ansys EmployeeHi,
It seems that SolidWorks 2017 is not supported in PlugIn Mode with Workbench 17.2 as per the documentation. So ideally first step would be downgrading your SolidWorks version to 2015 or 2016 to work with R17.2. Alternatively, you can also upgrade your ANSYS Workbench version to anything from R18.0 to R19.1 to work with SolidWorks 2017 in the plugin mode.
Also, after upgrading ANSYS version please check that you can manually change the parameter values, and those reflect in changes in geometry.
August 19, 2018 at 3:44 pm
wallygator88
SubscriberFigured this out.
The issue is not with the Solidworks version but rather with the fact that Maxwell requires you to define local variables for all your geometry parameters from Design Modeler so that you can parametrize them from WB
Cheers!
August 20, 2018 at 11:39 pm
Sandeep Medikonda
Ansys EmployeePlease mark your post as the answer so that someone might find it useful in the future.
October 20, 2018 at 9:57 am
squall0629
Subscriberhi wallygator88,I have met the same issue as you have , and i am really happy to know that you have found the answer , i want to know if i should define local variables name in maxwell exactly the same as the ones in SW? like you issue, the parameter 'DS_SQ' should be define in maxwell? even though it has no meaning in maxwell?
i need you help,thanks!
October 20, 2018 at 2:56 pm
wallygator88
SubscriberYou don't need to do that. In fact, I used different names.
October 21, 2018 at 2:25 am
squall0629
Subscriberhi wallygator88, thanks for the reply.but i still can not aunderstand if i used a different name ,how can workbench mapped the two parameter? is there any other things to do to map them?
i am a motor design engineer in china, email squall0629#gmail.com , maybe we can do further exchange on this or other ANSYS applying issues.
Thank you .
June 10, 2020 at 6:42 am
sunaa
SubscriberHi wallygator88,
I designed a geometry in DM, parametrized it, and imported into Maxwell. While I am trying to realize parametric simulation in workbench, I am still receiving this error even I enter the parameters used in DM as design parameters in Maxwell.
Screenshot from the parametric simulation from my setup tab is attached. I am changing 'dist' parameters (from DM and Maxwell) simultaneously, but Maxwell always reads constant value. I am really appreciated if you clearly tell how you overcame the problem.
June 13, 2020 at 8:41 am
BadDan2012
SubscriberHey i don´t know if it really helps, but i have a similar problem. Look into page 1333 of the Maxwell Help Release 2020. When you click on your imported geometry, you go to properties and there u put a new local variable into the value of the imported parameter.
Do you know how to make the imported parameter and the maxwell parameter automatically equal when running an optimization? In your picture for example your design point 0 is P1 dist=0.5 and P3 dist=0.5. When I start an optimzation, ansys put new design points for example -> P1 dist=0.3 and P3 dist=0.65, but they need to be equal.
June 15, 2020 at 3:34 pm
wallygator88
SubscriberHi Sunaa
This was a helpfule resource, especially the appendix
http://ansoft-maxwell.narod.ru/en/Maxwell_v16_L02_Geometry_Operations.pdf
June 27, 2020 at 11:13 am
sunaa
SubscriberThank you!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
