June 29, 2020 at 12:45 pm
AngelaStupp
SubscriberHey guys!
My issue is that workbench 2020 R1 doesn't get to solve. Solve starts meshing, but it stays there forever and never stops.
I designed a very simple object to test, but even this one it doesn't solve.
Thank you in advance
June 29, 2020 at 1:23 pm
Karthik R
AdministratorHello,
What physics are you trying to solve? And which tool are you using?
Could you please share some screenshots of your problem so we understand it better?
Thank you.
Karthik
June 29, 2020 at 2:51 pm
AngelaStupp
SubscriberHi!
I'm trying to analyze an object under tension force in the right side and fixed in the left. Material is structural steel.
I asked for equivalent stress and strain, and for total deformation. Just learning how to use the software.
As I ask to solve, it starts meshing (5%), but it doesn't go further and stays meshing non stop (always 5%).
The printscreen:
Thank you very much!
June 29, 2020 at 4:34 pm
Karthik R
AdministratorCould you please click on the status bar there? It should open up a pop-up window. What does the pop-up window say?
Thanks.
June 30, 2020 at 1:24 pm
AngelaStupp
Subscriber -
July 1, 2020 at 1:22 am
Karthik R
AdministratorCould you please try and coarsen the mesh to see if you are able to mesh your domain? If it is the RAM, at least, this should prove it.
Thanks.
Karthik
July 3, 2020 at 2:02 pm
AngelaStupp
SubscriberHi, Karthik!
It worked! I was using a mesh too small.
Thank you so much!
Best regards,
Ângela
July 6, 2020 at 1:15 pm
Karthik R
AdministratorPerfect! Could you please try and mark the most appropriate answers as 'Is Solution' so it benefits others on the community?
Thank you.
3812
2607
1853
1244
600
