July 13, 2018 at 9:45 am
Zarc
SubscriberHi Guys,
I have a question which refers to a steady state flow simulation in Ansys CFX. Is it possible to average contour or any other visualisation option over a certain number of iterations?
thank you for your help!
July 13, 2018 at 11:59 pm
raul.raghav
SubscriberYes, if you have created a backup file every, say "n" iterations. Then you can create an "iteration" (pseudo-time) averaged variable using a session file in CFD-Post. Read a little bit about session files and you'll be able to create a session script for doing this averaging easily. Let us know if you need help creating the session file.
May 6, 2023 at 7:44 pm
Yasser Alzahrani
SubscriberHi raul,
I am running a simulation in Ansys fluent and I need to get an iteration averaged velocity contours. Could you please guide me through the steps for saving a backup file for every iteration and then creating the session file for obtaining the iteration averaged contours?
Thanks in advance,
Yasser
7818
4514
2979
1453
1322
