March 15, 2022 at 12:48 pm
mmarch
SubscriberHi,
What is the unit of the y-axis in this IV curve? https://support.lumerical.com/hc/en-us/articles/360044943374-My-First-Simulation-Analyzing-Results-Demo
And how is this current related to the norm length in the Solver?
Thanks in advance
March 17, 2022 at 6:23 pmKhashayar Ghaffari
Ansys EmployeeHi The unit for reported current in CHARGE is Ampere (A). This is the case for both 3D and 2D simulations. In 2D, CHARGE uses the norm length value to calculate current for the equivalent 3D structure.
Best regards
- Error on Lumerical device
2702
2138
1355
1142
462
