Ansys Products
Ansys Products
Job was not run on the cluster. Check the cluster logs and check if the cluster is configured propr
    • yskalencat
      I have configure the Ansys2019R2 RSM on HPC with as follows
    • yskalencat
      Log file detailsn2021-02-02 12:55:18 [INFO] UserProxy started as hessamedinn on loginn2021-02-02 12:55:18 [DEBUG] Running on Monon2021-02-02 12:55:18 [INFO] UserProxy startedn2021-02-02 12:55:18 [INFO] Version 19.4.420.0 [Monday, 08 April 2019 10:09]n2021-02-02 12:55:18 [INFO] User: hessamedi2021-02-02 12:55:18 [INFO] PID: 19865n2021-02-02 12:55:18 [INFO] Proxy Idle Timeout: 0:10:00n2021-02-02 12:55:18 [INFO] Port: 40308n2021-02-02 12:55:18 [INFO] Port: 40308n2021-02-02 12:55:18 [INFO] Created MemoryMappedFile named USERPROXY194_HESSAMEDINN_HESSAMEDINNn2021-02-02 12:55:53 [DEBUG] TransferServer2 created.n2021-02-02 12:55:53 [DEBUG] TransferServer2 disposed.n2021-02-02 12:55:54 [DEBUG] AssemblyResolver: Loading /workarea/athenasoftwares/ansys2019R2/ansys_inc/v194/RSM/bin/FrameworkDependencies/Ans.Rsm.Localization.dlln2021-02-02 12:55:54 [DEBUG] AssemblyResolver: Loading /workarea/athenasoftwares/ansys2019R2/ansys_inc/v194/RSM/bin/FrameworkDependencies/netstandard.dlln2021-02-02 12:56:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:57:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:58:14 [DEBUG] TransferServer2 created.n2021-02-02 12:58:14 [DEBUG] TransferServer2 disposed.n2021-02-02 12:58:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:59:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:00:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:01:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:01:38 [DEBUG] TransferServer2 created.n2021-02-02 13:01:38 [DEBUG] TransferServer2 disposed.n2021-02-02 13:02:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:03:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:04:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:05:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:06:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:07:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:08:07 [DEBUG] TransferServer2 created.n2021-02-02 13:08:07 [DEBUG] TransferServer2 disposed.n2021-02-02 13:08:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:09:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:10:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:11:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:12:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:13:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:14:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:15:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:16:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:17:19 [DEBUG] ProcessActivityTracker shows activity.n
    • Mangesh Bhide
      Hello,nPlease verify if the arcnode services were started on the compute nodes and if the compute nodes were correctly added to the queuesnlook up arcstatus and arcqueues in documentationnif the ossue continues then can you right click in the RSM job log and click show debug messages and post screenshots of the log nthank youn
    • yskalencat
      nI configures as per documentation but get this errornthe log file for RSM and there is no log file arcnodenn
    • yskalencat
      the arcnode process is not reached even if it connected to master service and the arcnode is running on compute noden
Viewing 4 reply threads
