Joint Probe Results
    • utkug
      Hello,nI am using OUTRES, BASIC, All to reduce my result file size. However, I realized that only the last result has been saved at the joint probe. I was wondering if there is a way to add joint probe results to the OUTRES command.nUtku n
    • Ashish Khemka
      nnCan you try OUTRES,NSOL,ALL?.Regards,nAshish Khemkan
    • utkug
      ,nI tried the NSOL option, however it didn't work. I tried the ESOL option and realized that the probe values were saved. I used the MISC option just for the probes here is my command snippet.nOUTRES,ERASEnOUTRES,MISC,ALLnThis way, I got the probe results and the result size was reduced by almost 10 times.nThanks for your help!nUtkun
    • Ashish Khemka
      nnThanks for the update.nnRegards,nAshish Khemkan
Viewing 3 reply threads
