Joints with Friction
    • kpriu
      I am creating a simulation in Rigid Dynamics, where I test the effects of best and worst case friction. I have defined a nonzero coefficient of friction for each joint, but when I increase the coefficients of friction, the force at the joints decreases, which does not make sense. This is leading me to assume I have done something wrong, since I am relatively new to the program. Is there anything else I need to do to properly create a joint with friction other than defining the joint and setting the coefficient of friction?
      Note: I have tried adding a contact region at the joint, but that does not seem to change anything.
    • greg2835
      Hi kpriu, can you provide a descriptive layout of the assembly and the the joints defined?
    • kpriu
      I have attached a screenshot with the joints. There is a motor that outputs translational motion, and when it pushes the bottom of an arm (TranslationalArm) forward, that arm pivots about its center, and the top of the arm then pulls the bracket (LeftBracket) it is connected to back. That bracket is connected to another bracket by two arms, so when that bracket rotates backwards, the other one does as well.
