April 12, 2023 at 5:35 pm
Marvin Oliveira
SubscriberHello
I'm trying to simulate a joule effect on a tungsten wire,
but I don't know how to put the boundary conditions.
I only put current data on one side and a voltage equal to 0
on the other side of the wire? Do I need to put more boundary conditions in addition to these?
Can I use voltage instead of current to simulate the joule effect?
In my case I have the experimental data of both voltage and currentthank you very much
April 13, 2023 at 2:15 pm
Anchal Singh
Ansys EmployeeHello Marvin,
Can you please let us know which Ansys tool you are using?
Regards
Anchal
April 14, 2023 at 2:41 pm
Ashish Khemka
Ansys EmployeeHi Marvin,
Please see if the following link helps:
Ansys Mechanical Discussion 7 : Joule heating modelling in Ansys Mechanical - YouTube
Ashish Khemka
- Maxwell, HFSS or Q3D?
- Error
5268
3299
2469
