Journal file UDF
    • paola_1
      Hi, there's a way to write a journal file for compiling a UDF (without hooking the function), run calculate for one time step, hooking the function and run calculate for other time steps?
    • DrAmine
      Yes for sure. You need to just record the journal and navigate in TUI to execute the commands. The finalized journal can be then used to automate it.
    • paola_1
      Can you help me? I can't find the command to hook the functions.
    • paola_1
      I did it. Thank you.
      Forum Moderator
      please post the answer here so the next time someone's looking for it they can thank you for sharing.
    • paola_1
      Of course.
      File example is a file with the UDF but not with the hooked functions.
      /file/read-case /example.cas
      /file/read-data /example.dat
      /solve/set/time-step 0.002
      /solve/dual-time-iterate 1 50
      /define/user-defined/function-hooks
      adjust
      n1::libudf
      n2::libudf
      n3::libudf
      q
      /solve/dual-time-iterate 18 50
      /file/write-case /ex1.cas
      /file/write-data /ex1.dat
      exit
      OK
    • DrAmine
Viewing 6 reply threads
