JT effect simulation in Fluent
    • itsme_tilak
      Hello Folks!
      For the past few days, I have been trying to simulate the JT effect in Fluent to observe the effect of pressure change on temperature but I am not getting any result. To tell the truth, temperature is increasing as it passes through the orifice but it is supposed to decrease. To make it more clear, I use inviscid model, energy equation and pressure inlet.
      Could anyone help me to fix this? It would be a great help.
      What gas density are you using?
    • DrAmine
      You require Real Fluid Properties: so either CEOS or NIST EOS or RGP (based on NIST RefProp) in Ansys Fluent.
    • itsme_tilak
      I am using Methane as a fluid that has specific density of 0.554
      And how does a fixed density work for the JT theory?
    • itsme_tilak
      I am using a Density-based solver
      OK, and what is the material density?
    • DrAmine
      how will you see JT effects using constant density? Or even using Ideal Gas EOS? Can you explain?
Viewing 7 reply threads
