Discovery Import
Discovery Import
Junction of profiles
    • mi.fura
      Hello.
      I want ask, if we use beam profiles, is possible use something similar on these profiles, as function (junction) at sheet metal?
      Picture is in attachment.
      Thank you.
      Best Regards
      Miki
    • Naresh Patre
      Hello Miki
      Although there are no junction types available under beams, you could achieve the desired output using Orient tool. See below snapshot. You can move the beam profile and match it with your junction profile.
