January 27, 2018 at 2:16 am
sean.doughty
SubscriberHello,
In the ANSYS t junction tutorial the orientated selection set of the vertical section point outwards away from the horizontal section. However, this is not always possible for more complicated geometries.
I ran two cases, one with the selection sets pointing away and one with them pointing towards and got vastly different results. I am not quite sure about how to properly model a carbon fiber junction in ANSYS and to model the fact that there is a fillet joining the faces
I have attached my results. The outside had failure = 0.55 and the inside had failure = 0.77 for the exact same loads and mesh.
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2656
2120
1345
1118
461
