Kelvin-Helmholtz instability in an inviscid setting?
    • Karthik R
      Administrator
      I'm reading about the Kelvin-Helmholtz instability. Can this instability occur in an inviscid setting?
      Thank you
    • Keyur Kanade
      You are absolutely correct. KH instability requires the following conditions: two uniform flow of different velocity and density that are incompressible and inviscid. The instability sets in when the following instability condition is met.
      (U1-U2)^2 > g(rho1^2 - rho^2)/(alpha * rho1 * rho2)
      where,
      alpha = 2*pi / lambda,
      lambda is the wavelength of the disturbance,
      subscript 1 and 2 refer to fluids 1 and 2.
      This instability manifests as roll-up vortices examples of which include the famous Jupiter's Red Spot and cloud formation.
      I hope this helps.
      Thank you.
