September 10, 2019 at 9:38 am
akasha510
SubscriberHello guys,
I am trying to do simulation of keypad structure. and want to make like below force-displacement diagram. But, unable to draw this one. material is silicone. i give displacement and get force reaction. But, force-displacement diagram is totally different. just straight line.
Please help me
September 10, 2019 at 11:38 am
SubscriberPlease show the Analysis Settings. Did you turn on Large Deflection?
Did you turn on Auto Time Stepping and then set an Initial, Minimum and Maximum number of Substeps to be 100?
Do you have Frictional Contact defined at the switch contacts?
September 11, 2019 at 8:00 am
September 11, 2019 at 4:16 pm
SubscriberUnder Analysis Settings, turn on Stabilization.
September 12, 2019 at 2:22 am
akasha510
Subscriberstabilization - constant, Still getting same error. and also change the mesh size.
error- unable to converge on a solution for nonlinear problem as constrained.
2066
1279
1096
459
