January 25, 2023 at 4:43 am
rakesh_krishna
SubscriberI am trying to launch the Lumerical interconnect simulation of a layout in lumerical. For this I followed the intructions listed on (https://github.com/SiEPIC/SiEPIC_EBeam_PDK/wiki/Installation-instructions)First I installed the CML models in "Design kits" section of the "Element library" in Lumerical.The final step "Part 4" on the github page suggests testing the simulation connectivity between the lumerical interconnect and KLayout by opening up a layout ("Double-bus ring resonator sweep") and following the SiEPIC-> Simulation, circuits->Circuit simulation: Lumerical InterconnectWhen I follow this step, first thing I get is the errorAfter pressing cancel, a new message box pops up "Cannot find Lumerical" . Am I missing something here related to API (Lumerical Python API feature)? Where I check if it is present or procure it? -
January 26, 2023 at 7:11 pm
Guanhui Wang
Ansys EmployeeHi Rakesh,
Thank you for the post. We actually developed Lumerical tools KLayout integration based on the SEIPIC tools: https://optics.ansys.com/hc/en-us/articles/4411236218387-KLayout-Interoperability-Overview-, and you may want to check out this workflow as well. For your workflow, the problem seems to be in the license. Which OS are you using and where you install Lumerical tools to?
January 26, 2023 at 11:19 pm
- Error on Lumerical device
2524
2066
1279
1096
459
