Lamination on electrical machines
    • Charlotte Blair
      Why the cores of the electrical machines are laminated instead of machining from solid block of steel?
    • rtk
      Hello @cblair ,
      The cores of the electrical machines are laminated and are also insulated to reduce the induced circulating current also called eddy currents.
    • Charlotte Blair
      Hi @rtk ,
      Eddy currents! How do they effect Electrical machines?
    • rtk
      Hi @cblair ,
       If the core is not laminated, eddy currents will cause a considerable loss in the cores of electrical machines which results in the excessive heating of the machine.
    • Charlotte Blair
      Thank you @rtk for your explanation. ?
Viewing 4 reply threads
