March 22, 2022 at 8:32 am
turanyank
SubscriberHi,
Is there any property to check intereface of parts in large assemblies automatically?
Thank you,
Anton
March 22, 2022 at 11:30 amAshish Khemka
If a contact is created at the region of interest then using Contact Tool you can find the initial contact status to check for interference. Following links might help you:
Fundamental Topics in Contact | Ansys Innovation Courses
Contact Tool (ansys.com)
Regards Ashish Khemka
March 22, 2022 at 11:35 amturanyank
Thank you for responding. Sorry about that I should say spaceclaim. I am doing assembly in spaceclaim and not sure about interface that I missed. Is there any property for check it automatically?7
Thank youMarch 22, 2022 at 11:54 amViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2684
2124
1349
1136
461
