February 16, 2021 at 9:15 am
VishalAstekar
SubscriberCan anyone tell what is the amount of deflection that should be considered as large, in order to decide whether the option of Large Deflection should be switched on?nThanks in advancen -
February 16, 2021 at 10:50 am
Erik Kostson
Ansys EmployeeSo ideally we should always use large deflections - linear static (no large deflections) is in theory only valid for infinitesimal displacements, so always best to run it with large deflections.n(There are some rule of thumbs , say for a simple beam or plate bending - we can say that roughly if out of plane displacements are larger than about a quarter of the plate thickness then we can/are starting seeing nonlinear geometric effects - also if bodies have rigid body motion/rotation, then we need large deflections also, since otherwise we might see some stresses which should not be there during such a motion).Erik -
February 16, 2021 at 10:59 am
VishalAstekar
SubscriberThanks for the reply.. But if we always keep the large deflection on, it usually increases the solver time.. n -
February 16, 2021 at 1:25 pm
SubscriberYes, that's why you have the option to turn it off if it is unnecessary.n -
February 16, 2021 at 1:54 pm
VishalAstekar
SubscriberIs there any standard or deciding factor which mentions what should be considered as large deflection? n -
February 16, 2021 at 9:29 pm
SubscribernYes, said what that is in his reply, 1/4 of the plate thickness.n -
February 17, 2021 at 1:23 am
VishalAstekar
Subscriberbut this you will know only after running the analysis? n -
February 17, 2021 at 12:57 pm
SubscriberNot unless you are applying a displacement load, or have a hand calculation for a force load to estimate the deformation.n -
February 17, 2021 at 1:24 pm
VishalAstekar
SubscriberThanks Thanksn
3275
2453
