July 23, 2018 at 10:37 pm
guillermo.parraguez
SubscriberHello everyone:
I want to ask you what are the considerations taken into account in numerical simulations when the "Large Deflections" option is set in "On". I'm modeling a steel moment connection and when I compare the hysteresis curves without and with "large deflections", I observe that there's small diferences between the maximum capacity of the connection but I'm not sure if I can continue my research keeping the "Large Deflection" in "Off" because I don't know what considerations this option adds to the numerical model.
Thank you for your help!
July 24, 2018 at 12:20 am
Sandeep Medikonda
Ansys EmployeeHi Guillermo,
Looks like you do have material non-linearities and it is always recommended to have Large deflection ON in these cases. How much of a deformation are you seeing in your model? Maybe it isn't large enough for you to see a difference? Check out the following resources that talk about this in detail:
Sandeep
2078
1289
1106
459
