large size UDF file compilation problem
    • student90
      Hi
      I have a dynamic mesh model which I have defined the time dependent mesh deformation via a UDF. with a coarse mesh my UDF is compiled without any problem. but when I increase mesh quality, I can not compile my UDF via Fluent. when I press "build" to create library, after a while I see below message:
      fatal error C1128: number of sections exceeded object file format limit: compile with /bigobj
      does anyone know how can I fix this problem?
      thanks in advance
    • DrAmine
      It would require adding a compiler flag (bigobj) by hand and then compiling by hand. I cannot tell more here on this open community. Provide an eligible university address.
    • student90
      Here is my university Email address: mmehri@uwyo.edu
      we also have Ansys 2019 R1 license.
      thank you
    • DrAmine
      I will try responding as soon as I can.
Viewing 3 reply threads
