September 10, 2023 at 2:30 pm
Hila Shalom
SubscriberWhen I limit the source wavelength to a specific range (with a width of 100 nm), what should be the ratio between the source wavelength and the mesh size and with the PML?I'm trying to simulate the ability of a material to be a laser.What is a better monitor for this purpose ? DFTMonitor plane at the end of the nanotube or lowQanalusis analysis group? -
September 11, 2023 at 6:27 pm
Guilin Sun
Ansys Employeeare you simulating laser or cold cavity for lasing?
the mesh size should be choosen by the min wavelength inside the material. You can sepecify the wavelength range in FDTD advanced:
There are different monitors for you, depending on your desired results.
Monitors - Introduction and Common Settings - Common Settings and Tips
Q analysis depends on the cavity Q. https://optics.ansys.com/hc/en-us/articles/360041611774-Quality-factor-calculations-for-a-resonant-cavity
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2963
1449
1322
