Ansys Products
Ansys Products
Launcher.exe – Entry Point Not Found………… Could not be located in the dynamic link library…
    • Ahmed1400
      I installed ANSYS 2020 R1, but when I tried to open Fluent, I recive this message (( Launcher.exe - Entry Point Not Found............ Could not be located in the dynamic link library...)) Please help me what should I do ?
    • Keyur Kanade
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Moving to installation category.
    • tsiriaks
      Open CMD Prompt and enter the following command
      "%awp_root201%fluentntbinwin64fluent.exe" 3d -g -t0
      does this launch Fluent ?
      Also, do you have install.err file under C:Program FilesANSYS Inc  ? If so, please post its content here.
    • Ahmed1400
      Thank very much for replying...
      1. I tried this command "%awp_root201%fluentntbinwin64fluent.exe" 3d -g -t0 but it does not work,  and I did not find a folder with this name (install.err)
      2. + the fluent, also I can not  open CFX 2020 R1, and also Watertight Geometry Workflow.... and others apps.
      the version I used is Student version 2020 R1.
      Ex: These messages I got when I tried to open CFX
    • Ahmed1400
      Any Help Mr. Tsiriaks
    • tsiriaks
      Open CMD Prompt, then type
      set
      and post the output of it here
      Also, the install.err is a file, not a folder. For your case, it should be under C:Program FilesANSYS IncANSYS Student
    • Ahmed1400
      1. Below is the output
      2. I searched the file install.err but I didnt find it.
    • Ahmed1400
      Dear Win
      I solved the problem by resting my windows, now everything is working normally except the display of fluent! when I open it, everything is bigger than normal.
    • tsiriaks
      You mean you reinstall the OS ? That's pretty extreme but glad it helps with the issue.
      This looks fine to me but if things are bigger than you expected, it may have something to do with your computer display settings. See if it's at default scale (100%) , also check your display resolution setting.
      Thanks,
      Win
    • Ahmed1400
      Yes I reinstall the OS.
      I changed the  display settings and now it looks very fine.
      Thank you very much Win
    • tsiriaks
      You are welcome ! Glad to hear all is good for you now.
      Win
Viewing 10 reply threads
