TAGGED: ansys-electronics, ansys-icepak, ansys-student, cfd-tutorials
December 16, 2021 at 8:25 am
vasudevrg
SubscriberHey, Could someone kindly let me know how to launch classic ICEPAK from the Ansys Student Electronics suite?
When I select the launch classic ICEPAK option I am getting the following error (attaching Image for reference)
Thank you!
December 20, 2021 at 3:12 pmSatyajeet Padhi
Ansys EmployeeHi
You would need to have Classic Icepak installed on your system to launch it from AEDT.
December 21, 2021 at 4:41 amvasudevrg
SubscriberThank you for the Reply!
For clarification does that mean classic ICEPAK is not part of the Student AEDT. Are there some other student suites that offer a student version of "Classic ICEPAK"?
February 1, 2022 at 12:43 pmb_ram
SubscriberHi, same question here, is there a way to install student version of classic ICEPAK ? would be super helpful. Thank you.
- Maxwell, HFSS or Q3D?
- Error
3866
2639
1859
1260
606
