June 28, 2022 at 6:42 am
June 28, 2022 at 6:53 am
Charudatta Bandgar
SubscriberLet me check this, GUICAD . I will get back to you.
Regards.
June 28, 2022 at 3:28 pm
Charudatta Bandgar
SubscriberHello GUICAD
This is the correct process. I would suggest not using headless or exit after script and see if the first part is working. It could be a name or path issue. Or you can also just run the script interactively to make sure the script is working as expected. Let me know if it helps.
Regards.
June 29, 2022 at 8:07 am
Guillaume ANFOSSI
SubscriberCould you please check on your side ?
I tried with this command but it does not work.
C:Program FilesANSYS Incv221scdm>spaceclaim.exe /RunScript="C:temptest.py"
SpaceClaim opens but the script is not launched.
I tested with discovery and it works
3862
2639
1859
1254
600
