December 2, 2020 at 5:32 pm
FlorianHenscheid1
SubscriberHey Guys i am looking forward to calculate a LBA for cylindrical shells with different boundary conditions (bc1r, bc1f, bc2r and bc2f). The eigenvalues/eigenforms that i get for small shells (Lenght<300mm), however, do not look right and do not really converge. The code is attached as well as a picture of one eigenform.
Thanks
December 2, 2020 at 5:35 pmFlorianHenscheid1
SubscribernnDecember 21, 2020 at 9:14 amAshish Khemka
Forum ModeratornnPlease see if the following example helps:nnnRegards,nAshish KhemkanViewing 2 reply threads- The topic ‘LBA Cylindrical Shell (Steel) under torsional load’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
