December 21, 2022 at 8:49 am
Vratislav Košek
SubscriberHello everyone,
I would like to ask for advice. I have problem simulating an explosion using the LBE coupling to the MM-ALE method. I can t get the shock wave to pass throught the ambient layer to the ALE domain (air). I have no idea what the problem could be. I would appreciate any advice or link to working keyword deck for this method.
Thank you
December 27, 2022 at 5:02 pm
Jim Day
Ansys EmployeeI ran a similar test case and the pressure in the ambient ale elements does transmit to the rest of the ALE domain. Below are some guidelines. It appears you've correctly followed nos. 1 and 2. Check nos. 3 and 4. If that doesn't help, tell me which version of LS-DYNA you're running. 1) A one element thick layer of the ALE air domain which faces the blast source is given a new part ID. This new part is assigned material properties identical to those used in the rest of the air domain. In the *SECTION_SOLID definition of this new part the ambient type is set as AET=5. 2) The segments of the part described above which face the blast source are treated with *LOAD_BLAST_SEGMENT(_SET) and in that keyword IALEPID is set equal to that part ID number. 3) Currently the feature works only for air modeled using the ideal gas law with *EOS_LINEAR_POLYNOMIAL. The equation of state should be set up so that its initial pressure is equal to atmospheric pressure. 4) PREF in *CONTROL_ALE should be set to atmospheric pressure.-
December 28, 2022 at 1:58 pm
Vratislav Košek
December 28, 2022 at 6:18 pm
Jim Day
Ansys EmployeeYour simulation runs to Normal Termination? To confirm whether pressure transmits into the non-ambient air, overlay a pressure time history of a blue, ambient element with a pressure time history of a nearby red, non-ambient air element. Post that image.-
December 29, 2022 at 9:08 am
December 29, 2022 at 5:27 pm
Jim Day
Ansys EmployeeSo you're concerned about the difference between the pressure loading on the surface of the ambient layer and the pressure seen in the ambient element. As an experiment, remove the *LOAD_BLAST commands and apply the pressure from blstfor directly using *LOAD_SEGMENT_SET. Do you get the same response? -
December 30, 2022 at 1:25 am
Jim Day
Ansys EmployeeI think what you've plotted from blstfor is "P=(Pi,Pr,theta)". Note that blstfor also includes "Pi" or "incident pressure". I think that incident pressure is what is applied to the ambient air elements in the coupled ALE approach. A number of papers on the subject of *LOAD_BLAST_ENHANCED may be found through dynalook.com or simply by Googling "*LOAD_BLAST_ENHANCED".
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2600
2086
1317
1108
459
