December 5, 2022 at 3:27 pm
December 5, 2022 at 9:31 pm
John Doyle
Ansys EmployeeTry post processing contact status.
December 6, 2022 at 11:28 am
SubscriberHello Lovisa,
You sent me this link to an excellent tutorial on O-rings and fluid pressure.
You are using the APDL commands to add fluid penetration pressure as described in that tutorial.
In Workbench, using the Contact Tool, I plot Fluid Pressure as you have done.
The tutorial shows which edge to apply the pressure to and where to define the start_pt.
Best regards, Peter
December 6, 2022 at 11:29 am
December 6, 2022 at 11:35 am
December 6, 2022 at 12:16 pm
December 6, 2022 at 6:09 pm
December 7, 2022 at 1:18 pm
December 7, 2022 at 1:59 pm
SubscriberYes, the plots look different. The Workbench plot looks wrong. How can the pressure suddenly change from red to green when there is no contact? It should be red all the way around the curve since that is where the pressure should be applied. Is there a mistake in the model that causes this plot to look wrong?
The Tutorial model plot looks correct. Red is continuous along the edge until the O-ring makes contact and only then does it begin to turn green and then blue.
December 7, 2022 at 2:07 pm
December 7, 2022 at 10:56 pm
SubscriberPlease read the ANSYS Help description of the algorithm used in Fluid Pressure.
Fluid pressure along normal and tangential directions can penetrate into the contact interface from one or multiple locations. The fluid pressure-penetration load has a path-dependent nature. The penetrating path can propagate and vary, and it is determined iteratively. At the beginning of each iteration, the program first detects starting points which are exposed to the fluid pressure. Among the starting points, the program then finds fluid penetrating points where the contact status is open or lost, or where the contact pressure is smaller than the user-defined pressure-penetration criterion. When a contact detection point has a contact condition of “penetrating,” it is subjected to the fluid pressure, and its nearest neighboring nodes are considered to be the starting points which are exposed to the fluid pressure as well.
The fluid pressure is not applied to an area having a contact status of open unless the edges/ends of the area belong to the starting points.
After reading the above, it seems that choosing a point on the bottom of the O-ring is a better choice.
2120
1347
1118
461
