March 16, 2022 at 8:52 am
moranlouie
SubscriberHi, All!
I need help finding documentation on 'Learn Points' and goodness of fit.
- How many Learning Points does the Response Surface module generate when presenting the goodness of fit?
- What is the threshold of each metric (Coefficient of Determination, RMSE, etc.), for Ansys to decide to give stars, x, or gray bars?
I am specifically using a Rotatable Central Composite Design to generate experimental points. The particular surface in the screenshot was solved for using genetic aggregation.
Thanks for your help!
March 16, 2022 at 6:24 pmAshish Khemka
Please see if the following link helps:
Goodness of Fit Calculations (ansys.com)
Regards Ashish Khemka
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2524
2066
1279
1096
457
