May 19, 2022 at 10:22 am
anhkenyt
SubscriberHi all,
I want to use a python script to execute the "Home" button in order to have the best view before I save as a png file.
However, when I record, no history py appears?
Can I do that?
May 19, 2022 at 11:59 amAniket
Ansys EmployeeViewHelper.ActivateNamedView("Isometric",1,0)
This should work.
-Aniket
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8762
4658
3151
1678
1456
