March 25, 2021 at 9:33 am
riccardocasula
SubscriberWould it be possible to implement an LED model (or even a micro-LED) into INTERCONNECT in the same manner of TWLM and what would that require? Does my question make any sense?nMany thanksnRiccardon -
March 29, 2021 at 2:09 am
Guanhui Wang
Ansys EmployeeHi riccardocasula,nnIt is not easy to define incoherent light sources in INTERCONNECT though it is possible to import arbitrary waveform. It requires a file defines the time steps, magnitude and phase of the light signal: https://kx.lumerical.com/t/arbitrary-waveform-generators-from-file-for-interconnect/40965. I am not so sure this is very useful for the LED source.n -
March 29, 2021 at 4:05 pm
riccardocasula
SubscriberHi gwang, thanks for your reply. On the other hand I am also particularly interested in generating a waveform from a micro-LED as per the example offered. Do you advise anything in this regard? Regardsnn -
March 29, 2021 at 7:13 pm
Guanhui Wang
Ansys EmployeeHi riccardocasula ,nnIf you can get the waveform time step, magnitude and phase information from the micro-LED, you can just plug them in the text file as in the linked exmpale, then just load it into INTERCONNECT.n -
March 30, 2021 at 2:59 pm
riccardocasula
SubscriberHowever, but please correct me if I am wrong, it seems that the micro-LED model in FDTD does not simulate the generation of the EM fields from the materials as the dipole source is assumed, as well as its time signal which is arbitrarily set. Therefore the time signal recorded from time monitor after simulation wouldn't give the 'real' representation of the device waveform as this would depend on the electrical inputs. What solver could return a waveform of a micro-LED from an electrical input? There is this possibility? Thanksn
Viewing 4 reply threads
Trending discussions
- Error on Lumerical device
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
