Legend in Mechanical not interactive
    • sncyth
      I've a problem with the legend in my mechanical. I'm not able to enter values in the white boxes no matter what I do and I can't fix it one way or another. I've even tried reinstalling but the issue is still there. What's even stranger is that I'm able to adjust the values by using the drag and drop function of the legend but i can't enter a specific value at all. This porblem really bugs me because it's hard to compare diffrent results when you can't adjust the legend to each other.
      Has anyone stumbled across this problem before and knows how to fix it?
    • Gary Stofan
      The legend uses OpenGL functionality and requires a graphic card/chipset that is intended for 3D engineering applications.
      Are you using a laptop computer? If so, that may be the issue as most consumer laptops are not intended for 3D apps, and have limited OpenGL support.
      We recommend using one designated as a "Mobile Workstation" with nVidia or ATI graphics.
      You can easily find the graphics information by running "DxDiag.exe" then "Save All Information" DxDiag.txt
      In the meantime, you might want to install Ansys on a desktop computer and see if the issue persists.
    • sncyth
      Hi there sorry for my very late reply... Thanks for you answer Gary! However I don't think that this is the problem. I have a machine with a Quadro P2000 Graphics Card. My whole System is a designated "Mobile Workstation" so i guess the Problem must be somewhere else.
      Would the DxDiag be helpful anyways?
      Best Regards
    • Gary Stofan
      Hi
      Please try this:
      Double click the value,
      press End button on your keyboard
      Delete the old value by backspacing Type the new value and hit Enter.
    • sncyth
      Hi Gary I tried your solution but unfortunately it didn't work. To me it seems as I can't really click into the window. So even your first point "double click the value" has somehow no effect.
      Do you have any other ideas what could be wrong?
    • Gary Stofan
      Sometimes the settings become corrupt. Try this to see if it resolves the issue.
      Exit Ansys completely.
      In the File Explorer address field
      Enter: %APPDATA%
      ...An Explorer Window will open
      Open the Ansys folder...
      Rename the vNNN folder to vNNN.old for the appropriate version.
      ( v202 = 20202R1, v211 = 2021R1, etc)
      Try opening WB and Mechanical and try again.
    • sncyth
      Hello again so I tried deleting all the App Data. I guess it must have worked because a new vNNN folder was created and Ansys greeted me with all the new user windows. HOWEVER I still can't change the legend via clicking and entering numbers. I can click in the legend left click hold and drag to change the legend but that is not very accurate. I can also add and delete more legend entries. To be honest it's really strange and I'm starting to doubt my ability to click boxes (just in case I tried a few boxes in other programs and they all work fine ;) ).
      Any other Ideas what could be wrong?
    • Gary Stofan
      So you never get the white entry box?
    • sncyth
      So my answer to your question would be: Kind of.
      I've taken a couple screenshots to show my problem in more detail. So first Screenshot is how my legend looks without me having done anything:
      Second Screenshot is how it looks when I hover the mouse over the legend entries.
      Third Screenshot is me clicking once:
      Last Screenshot is me double clicking (mouse changes to the text editing symbol. I cant select the text or do anything with it)
      I hope this clears things up. If I can provide more information please let me know :)
    • Gary Stofan
      We have also seen this issue on some computers/graphics card combinations and is most often resolved with a later graphics driver.
      Go to nVidia.com, and obtain the latest driver for your Quadro P2000. Install per the instructions.
    • sncyth
      Hi Gary thank you for your ongoing support. Your last advice finally did the trick. Updating the graphics card drive resolved all my issues as far as I can tell!
      Thank you very much! :)
    • Erik Kostson
      That is great to see that you resolved this problem- sure users will find this very helpful should they encounter a similar issue.
      Erik
    • Vivekanandan A
      I face the same issue. Even after updating the Nvidia driver. Any help is highly appreciated. Thanks in advance.
      • Sampat Kumar
        Try to avoid asking duplicate questions in multiple forum threads. Further discussion related to this edit legend will be on the below-mentioned forum thread.
        https://forum.ansys.com/forums/topic/unable-to-edit-mechanical-contour-legend/
        Sampat
Viewing 12 reply threads
  • The topic ‘Legend in Mechanical not interactive’ is closed to new replies.
