March 10, 2021 at 6:01 pm
paola_1
SubscriberHi, how does Fluent calculate the lenght of vectors projected on a plane (in particular, a plane perpendicular to the x axis)?n -
March 11, 2021 at 2:22 pm
Karthik R
AdministratorHello,nIf I understand your question correctly, you should be able to find your answer in the following link. nBasically, Fluent is displaying only the vector components in the plane of the surface selected for display. If this does not answer your question, please let me know with a few screenshots of exactly what you are looking for.nKarthikn -
March 11, 2021 at 2:54 pm
paola_1
SubscriberOk, and the lenght of the vectors (which is not the same everywhere if I don't select fixed lenght) how is it calculated by Fluent? Based on velocity magnitude or based on the vector components?n -
March 11, 2021 at 3:02 pm
Karthik R
AdministratorAh...gotcha! nBy default, one vector is drawn at the center of each cell (or at the center of each facet of a data surface) and its length and color is based on the velocity magnitude at that cell center. Remember, this is always cell center data that Fluent plots.nKarthikn -
March 11, 2021 at 3:15 pm
paola_1
SubscriberOk, thank you.n
Viewing 4 reply threads
Trending discussions
Top Contributors
2628
2098
1327
1110
461
Top Rated Tags
