August 2, 2018 at 1:20 am
joepa_2017
SubscriberI am trying to manually mesh something using the LESIZE command in APDL. The documentation says that the syntax is the following:
LESIZE, NL1, SIZE, ANGSIZ, NDIV, SPACE, KFORC, LAYER1, LAYER2, KYNDIV
From what I understand, if I input a negative value for LAYER1, then the magnitude of LAYER1 should specify how many layers in the mesh have the size specified in SIZE.
For example, if I write: LESIZE, all, 0.1, , , 1, 1, -5, ,0
then I would expect that the value of -5 in LAYER1 implies that there should be 5 rows of elements with an edge size of 0.1. I am not observing this in the model. So either, I have misinterpreted the meaning of LAYER1 or I am missing something.
Any suggestions to get LAYER1 working would be appreciated. It seems like it would come in handy for my model.
Thanks!
August 2, 2018 at 2:33 pm
jpasquerell
Ansys EmployeeI think multiplier means 5 * 0.1 = 0.5 so 0.5 should be used as the element size for layer 1. Is that what you are seeing?
August 2, 2018 at 7:17 pm
joepa_2017
SubscriberMaybe. However, if that is the case, why not just specify the element size to be 0.5 on the line to begin with?
August 2, 2018 at 8:10 pm
August 3, 2018 at 2:18 pm
jpasquerell
Ansys EmployeeMy initial reply was incorrect. See the test input below. It appears that setting layer2 to a non-zero value is also needed to get that type of mesh.
/prep7
fact=5
rect,,11*fact,,3*fact
pcirc,2*fact,,0,360
wpoff,4*fact,3*fact
pcirc,2*fact,,0,360
wpoff,4*fact,-3*fact
pcirc,2*fact,,0,360
asba,1,2
asba,5,3
asba,1,4
et,1,200,4
save
lsel,s,,,5
lsel,a,,,11,14
lesi,all,0.1,,,1,1,-5,2,0
esiz,1
amesh,all
August 3, 2018 at 5:10 pm
joepa_2017
SubscriberThe good news is that your code works as desired.
The bad news is that for some reason mine does not. I have even tried layer meshing on a very simple geometry. When I run the following code on a rectangle, I still only get 1 layer of elements that have the desired size. Here is a sample code from a simple rectangle; I don't see what would be incorrect with it:
/PREP7
RECTNG,0,10,0,-5,
!Define element type
et,1,plane183
lsel,s,line,,3
keyopt,1,1,1
lesize,all,.05,,,1,1,-5,1,0
aesize,1,.5
amesh,1
August 3, 2018 at 5:22 pm
joepa_2017
SubscriberIt looks like it only works when using esize rather than aesize... That's unfortunate
August 3, 2018 at 6:47 pm
joepa_2017
SubscriberNevermind. It looks like the layer meshing works only when using esize rather than aesize. So, it is still possible to use if each area is meshed separately, and esize can be redefined between meshing each area.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
459
