April 7, 2018 at 7:01 pm
Tomas129cz
SubscriberI just installed student version 19.0 and started the Workbench and when I imported .stp file and run model, it wrote me this (picture). And geometry wasnt loaded.
I reinstaled it, deleted all, in app data too. Ofcourse I've used the recommended installation steps. Anything helped. I am desperate and please for help.
April 8, 2018 at 12:35 am
If you put your STEP file in a zip file, you can attach it to your post if the zip file size is < 120 MB and I can test it.
April 8, 2018 at 10:51 am
Tomas129cz
SubscriberI am student from https://www.vutbr.cz/en/ and I am working on project and we must create petrol engine. We are learning on it. So I created piston on Creo and assembled it with piston pin and exported to STEP.
But I had older version of Ansys and there when I imported this STEP file, all worked normally. But I reinstalled Ansys to newer version and this problem has arisen.
I just wanted to try, if Ansys will say me, that piston bolts are ok or not.
April 8, 2018 at 10:53 am
April 9, 2018 at 12:00 am
raul.raghav
SubscriberTom, you can zip the STEP file. You are trying to attach a .7z file which is not supported by the forum. The supported file formats are listed here.
April 9, 2018 at 4:20 pm
Tomas129cz
Subscriber -
April 9, 2018 at 6:53 pm
SubscriberOpen the Geometry editor, either DesignModeler or SpaceClaim first.
In DesignModeler, you use File, Import External Geometry File and pick the STEP file
In SpaceClaim, you Open and pick the STEP file.
I gave you a link in my first comment with this information. Did you read it?
If you are on a Student license, the solver will not run if you have more than 32,000 nodes plus elements. This is near the limit.
April 9, 2018 at 7:35 pm
May 14, 2018 at 3:14 pm
karthikyogi01
Subscriberrespected sir am also getting same problem which is shown by tomas129cz please help me
my model is attached. please find attached file and give the solution
am doing simulation in transient structural
name of the component in my drive is pin-on-disck_asm.stp and my drive link is shared below
https://drive.google.com/open?id=1W-oRtXpWMiLsjQXcFhL0kd_j2Wj6vE6f
thank you
May 15, 2018 at 9:54 am
June 13, 2018 at 8:58 pm
milen_D
SubscriberIs this 32000 node limit something new? I keep having issues with it and i dont ever remember having to deal with this last year when i used 18.1 ?
June 13, 2018 at 10:08 pm
SubscriberIt's not new.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5424
3391
2471
1310
1022
