March 30, 2018 at 10:19 pm
brian+discoverylive
SubscriberHi, I had a question regarding how ansysls_client.exe works. After automating the installation of ANSYS DL on a cloud instance, I log into the instance and run ansysls_client -ActivateLicenseEntitlementand get the attached screenshot (error1.png). After opening DL and signing into my account, it tells me I do have any subscription (error2.png). Finally, I call ansysls_client -ActivateLicenseEntitlement again and my license is activated on the instance. Could you please explain why I am seeing this behavior? The behavior I expected would be that the license would be activated on the first ansysls_client call. Thanks, Brian -
April 2, 2018 at 5:41 am
Naresh Patre
Ansys EmployeeHello RescaleBrian3
I will check with the team and get back to you.
April 3, 2018 at 8:47 am
Naresh Patre
It seems to be some issue with the MAC address not being initialized fully. Can you send ansysls_client.*.log (located at %temp%/.ansys) from this system showing the error? Also, send details about timezone of the system.
April 6, 2018 at 1:10 am
brian
SubscriberNaresh Patre Please see attached log. The log shows failing license activations going through the GUI, but a successful activation via calling ansysls_client from a cmd prompt.
April 6, 2018 at 1:13 am
brian
SubscriberNaresh Patre Time zone of the machine is UTC
April 10, 2018 at 9:29 am
Naresh Patre
The log does not seem to show the activation failure with the bad parameter. It only shows a successful activation and deactivation. It could be possible that the cloud instance that saw the issue is now gone. If you see the issue again please send the debug log files in the %TEMP%.ansys directory before closing the cloud instance.
April 10, 2018 at 4:35 pm
brian
SubscriberNaresh Patre Hi Naresh, from my log, the denied attempts were all from going through signing into my Discovery Live account after double-clicking the shortcut on my desktop. The successful activation/deactivation was through calling ansysls_client from Powershell. I would like to understand why this does not work through the GUI but works via Powershell/CMD.
April 11, 2018 at 9:28 am
Naresh Patre
Ansys EmployeeRescaleBrian I have been told that it is just a temporary glitch in the FNO server or network traffic between them which resulted in the issue.
Are you still facing the same issue?
April 11, 2018 at 1:27 pm
Naresh Patre
Ansys EmployeeRescaleBrian Can you set ANS_FLEXLM_DEBUG env var to a non-zero value (like 1) and then try the steps to reproduce the issue? Once done, please send all files from %temp%/.ansys folder for further investigation.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3670
2548
1749
1226
582
