November 20, 2020 at 7:58 pm
meljin
SubscriberHellonI am presently using the ANSYS Academic Research CFD (25 tasks). I can run each simulation on a cluster with a maximum of 16 cores for each simulation (which is the limit for built-in HPC).nIf I add-on the ANSYS Academic Research HPC (per core), will I be able to run each simulation with 32 cores?nthank youn -
November 23, 2020 at 11:52 am
Forum ModeratorThe 25 tasks refers to how many solver jobs you can run at once, each with 16 cores. So you can run 25 Fluent models each on 16 cores if you buy a bigger computer. The additional HPC pack will let you run one solver on more cores. Check that with us via contact us using your University email on how many as the core count looks different than for the commercial licence. n -
November 23, 2020 at 11:07 pm
meljin
SubscriberThank you very much.n
- The topic ‘License capabilities’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
