Ansys Products
Ansys Products
License connection issue
    • Yiting Jin
      This error cannot be solved by adding files into firewalls.
    • Rajeshwari Jadhav
      Hi Yiting,
      Check if you have the feature "lum_fdtd_gui" in your license file.
      If yes then, can you make entries in the host file: (You will require admin access)
      ·        Open the HOSTS file on the client machine and add the license server name and IP of the license server in that hosts file.
      ·        Path: “C:\Windows\System32\drivers\etc “ as per the following format in your client machine :
      Example:
      IP address of server            Hostname of server                     FQDN
      xxx.xxx.xxx.xxx                                                             //IP address of server and name. You can also add FQDN.
      ·        Add the below-mentioned line at the end of hosts file.
      ·        Once the entry is added save the file.
      ·        Launch the Ansys application.
      If you face any issues, send screenshot of it.
