November 12, 2020 at 3:51 pm
AStumpf
SubscriberHello,
I have following error:
November 16, 2020 at 2:27 pmANSYS_MMadore
Ansys EmployeeArray Can you please try renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old, where XXX is the version of ANSYS you are trying to run?.Thank you,nMattnNovember 25, 2020 at 11:06 amAStumpf
SubscriberThank you Matt,nbut this does not solved the issue.nKind regardsnArnenNovember 25, 2020 at 3:12 pmAStumpf
SubscriberHey,nthere was missing the systemvariable: LM_PROJECT.nI do not know why, but to add the variable solved the issue.nThank for your effortnArnennNovember 26, 2020 at 4:13 pmEricmonroe
SubscriberAlso I recommend view this review https://differencebtwn.com/difference-between-dissertation-vs-thesisnViewing 4 reply threads- The topic ‘License error: -5, 147’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1680
1470
